MF 5465 no start
   / MF 5465 no start #1
Dgross51
MF 5465
Starts only on ether, whether it is warm or cold, even at 75 ambient air temperature. Has new injectors, new supply and injection pump. Fresh overhaul, had low compression. Replaced crankshaft sensor, repaired faulty wire for the sensor to the ECM. Cranking speed is excellent. Once running, runs like a champ. Dealer ran a diagnostic test, but can't bring up but 1/3 of needed scans.
   / MF 5465 no start #2
Pull your injector lines and verify your pump is running properly.
You said it was overhauled for low compression, maybe the injector pump is on the wrong cam position and is timed wrong for low rpm.
   / MF 5465 no start #3
If the dealer can't communicate properly whit the systems on the tractor why don't they diagnose that fault?
   / MF 5465 no start #4
Using ether to start a tractor is not the best way to go. It has a much lower flash point than diesel and its use can potentially damage an engine. If the dealer can't diagnose the problem perhaps a real diesel mechanic can.
   / MF 5465 no start #5
I suspect it is out of time. Ether is a diesel engine killer. Good advice to have a real mechanic check it.
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2014 JLG G12-55A 12,000LB 4x4 Rough Terrain Telehandler (A50322)
2014 JLG G12-55A...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
