MF 491 Air Conditioner
   / MF 491 Air Conditioner #1
markwmo
Central Missouri
Kioti DK40SE, MF 491, MF 261
I have a MF 491 with cab that blows our cool air but not "cold". I feel like the system needs some refrigerant added but haven't been able to locate the ports where you add any or test. Does anyone know where they would be? Thanks
   / MF 491 Air Conditioner #2
yes they are located thru the plastic plug in top of the hood not real easy to get too but that will give you acess.
Thanks, I did find it. Ended up partially removing the hood for easier access. Hopefully recharging will fix it.
   / MF 491 Air Conditioner #4
you probably done checked this but make sure your radiator and ac condenser are clean and free of dirt and debris.
   / MF 491 Air Conditioner #5
If you look closely I believe there is a coolant hose that goes up into the cab - that is how the cab blows heat in the winter. However, that hose will bring engine coolant into the cab year around - you might want to install a shut off valve (gate valve/ball valve) in that coolant line and turn the valve to the OFF position in the summer time to make the A/C more efficient.
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2019 HINO 268 26FT BOX TRUCK (A52576)
2019 HINO 268 26FT...
Manac Walking Floor Trailer (A50322)
Manac Walking...
