MF 491 Air Conditioner
   / MF 491 Air Conditioner #1
markwmo
Central Missouri
Kioti DK40SE, MF 491, MF 261
I have a MF 491 with cab that blows our cool air but not "cold". I feel like the system needs some refrigerant added but haven't been able to locate the ports where you add any or test. Does anyone know where they would be? Thanks
   / MF 491 Air Conditioner #2
yes they are located thru the plastic plug in top of the hood not real easy to get too but that will give you acess.
Thanks, I did find it. Ended up partially removing the hood for easier access. Hopefully recharging will fix it.
   / MF 491 Air Conditioner #4
you probably done checked this but make sure your radiator and ac condenser are clean and free of dirt and debris.
   / MF 491 Air Conditioner #5
If you look closely I believe there is a coolant hose that goes up into the cab - that is how the cab blows heat in the winter. However, that hose will bring engine coolant into the cab year around - you might want to install a shut off valve (gate valve/ball valve) in that coolant line and turn the valve to the OFF position in the summer time to make the A/C more efficient.
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
