MF 451 CLUTCH PEDAL
   / MF 451 CLUTCH PEDAL #1
PJR968
MARKHAM, VA
MF 451
WHEN I DEPRESSED THE CLUTCH PEDAL, SOMETHING MADE A NOISE AND THE PEDAL WONT RETURN TO THE PROPER HEIGHT. I STILL HAVE SOME TRAVEL, BUT NOT ENOUGH TO RELEASE THE CLUTCH. ALL THE LINKAGE VISABLE SEEMS FINE. I CAN'T FIND ANY INTERNAL LINKAGE IN MY PARTS MANUAL.
   / MF 451 CLUTCH PEDAL #3
Before looking to more involved causes, verify proper adjustment of pedal free travel. The procedure is in your owners manual and can be done externally. It is possible that the shaft has slipped in the clamp.
SDT
THANKS, I WILL CHECK WHEN THE WEATHER CLEARS.
   / MF 451 CLUTCH PEDAL #5
When you say you heard a noise leads me to believe it was one quick noise and not a constant noise.
Can you describe the noise.
was is a constant noise that continued while the pedal was pushed in or
did you hear it one time when you pressed it in.
2012 CHEVROLET 3500HD SILVERADO LS DUALLY TRUCK (A51247)
2012 CHEVROLET...
WOODS RT48.30 LOT IDENTIFIER 219 (A53084)
WOODS RT48.30 LOT...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
