MF 451 CLUTCH PEDAL
   / MF 451 CLUTCH PEDAL #1
PJR968
MARKHAM, VA
MF 451
WHEN I DEPRESSED THE CLUTCH PEDAL, SOMETHING MADE A NOISE AND THE PEDAL WONT RETURN TO THE PROPER HEIGHT. I STILL HAVE SOME TRAVEL, BUT NOT ENOUGH TO RELEASE THE CLUTCH. ALL THE LINKAGE VISABLE SEEMS FINE. I CAN'T FIND ANY INTERNAL LINKAGE IN MY PARTS MANUAL.
   / MF 451 CLUTCH PEDAL #3
Before looking to more involved causes, verify proper adjustment of pedal free travel. The procedure is in your owners manual and can be done externally. It is possible that the shaft has slipped in the clamp.
SDT
THANKS, I WILL CHECK WHEN THE WEATHER CLEARS.
   / MF 451 CLUTCH PEDAL #5
When you say you heard a noise leads me to believe it was one quick noise and not a constant noise.
Can you describe the noise.
was is a constant noise that continued while the pedal was pushed in or
did you hear it one time when you pressed it in.
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2022 BOBCAT T64 R-SERIES SKID STEER (A51246)
2022 BOBCAT T64...
Electric Concrete Mixer (A51573)
Electric Concrete...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
