MF 3660 trying to run John Deere 7200 planter..help
   / MF 3660 trying to run John Deere 7200 planter..help #1
duckngooser
NW Missouri
New Holland TB100 & Massey Ferguson 3660
Hello. I have a Massey Ferguson 3660 with 3 sets of hydraulic remotes. I recently aquired a John Deere 7200 series planter. The planter requires a continuous hyrdaulic flow to run the blower motor.
With that being said, I was told awhile back by a Massey dealer how to crank down the pressure and adjust to get the desired flow rate. However, I was also told that the return line needs to be zero restriction, meaning the return hydraulic line must drain straight into the hydraulic tank. It was mentioned that there should be a plug with a hex head that I can remove and pipe the hydraulic line to the tank with a fitting? I've looked around and I'm not seeing it....
Need some help....Thanks in advance!
   / MF 3660 trying to run John Deere 7200 planter..help #2
give me a call. I have a 3660 also and am going to run a 1760 deere planter this year. I will give you some insight as to what I know about it. (605)830-2291
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
FAKE (A52472)
FAKE (A52472)
Towable Orchard Sprayer (A51691)
Towable Orchard...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
