MF 36 Hay Rake, is it a good rake?
   / MF 36 Hay Rake, is it a good rake? #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
Hello, I got a chance to get a MF 36 Hay Rake tomorrow for $400. Being new at all this I was wandering how good of a rake is it? Any tips on using this type of hay rake (side rake)? I doesn't come with a manual so i have no idea how it works. Are parts still available for it? Anything I should look for when I look at it to know if it will be a good buy or a money pit?
Thank you.
Corey.
   / MF 36 Hay Rake, is it a good rake? #2
Is it PTO or ground driven.
   / MF 36 Hay Rake, is it a good rake? #4
I've used a mf 36 for the last 3 years. It was in rough shape when I bought it but it did the job well. Paid 100 bucks it crapped out this year. The internal gear drive sheared and I haven't had time to fix. They are fairly common so gettin a wrecked one for parts is easy enough. They are easy to use. Check the ground drive universals for excess play.
   / MF 36 Hay Rake, is it a good rake? #5
I have 2, pretty trouble free.
   / MF 36 Hay Rake, is it a good rake? #6
It has been great for me two years running. The tines can be bought from TSC. The two hole type not the single hole. But it does twist a tight windrow overall. If you want fluffy this does more rope type windrows. It is Very heAvy. It will hurt you or someone if not careful. Easily worth the 300 I paid. CG
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
John Deere 7130 (A50120)
John Deere 7130...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2017 Bobcat E32i Mini Excavator (A50322)
2017 Bobcat E32i...
