MF 35 Steering Box Rebuild
   / MF 35 Steering Box Rebuild #1
whodattractor
Texas
mf 2135
Hi, I'm rebuilding a steering box for a US MF 35 and I don't know where these two parts go. The brass one is an eyelet and the disc is a retainer. I know they go under the steering worm shaft and above the lower bearing, but how are they assembled? There is a small hole on the bottom of the worm shaft but the eyelet doesn't fit in there.
Also, I was reading the I&T shop manual and it says that to check the steering shaft preload you attach a spring scale to the steering wheel and that it should take 1/2 lb to 1 1/2 lbs to turn the steering wheel. What kind of spring scale do I need to use and how do I use it?
Thanks!
Year: 2004 Make: Sterling Model: Acterra Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2004 Make...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F450...
2020 Nissan Altima Sedan (A50324)
2020 Nissan Altima...
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
