MF 35 Diesel Tach Cable
   / MF 35 Diesel Tach Cable #1
Jobenfarm199
Big Clifty Ky
MF 35 Diesel
I was wondering if anyone has had problems with tisco's tach cables. I bought one a while back when the the factory cable's nut broke when it was tighten on the engine tach housing. The new one i bought the inner cable was too short and would not turn the tachometer. I replace the new inner cable with the old cable and it worked good, but the new problem was the outer housing will not fit tight against the engine tach houseing due to the outer cable housing being too long. I have a MF Parts book and i took the mesurments of the inner cables and compared them to the mesurments that parts book showed. The new cable tisco stock were wrong with the cable. One number is for a shorter tach cable which for the older serial numbers and the longer one being for new serial numbers
   / MF 35 Diesel Tach Cable #2
Hi All,
I've just bought an old MF35 with no tacho cable. I have no idea where the drive point for this this cable is. Any ideas?
   / MF 35 Diesel Tach Cable #3
Should be off the back of the fuel injection pump. The drive mechanism is just like a speedometer cable.
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
LMC G500-500A LOT IDENTIFIER 218 (A53084)
LMC G500-500A LOT...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
1996 UTILITY 101" X 52' T/A FLATBED TRAILER (A51247)
1996 UTILITY 101"...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
