Oil & Fuel MF 35 Diesel CAV Pump
   / MF 35 Diesel CAV Pump #1
Jobenfarm199
Big Clifty Ky
MF 35 Diesel
My 35 was leaking fuel from the top of the pump. I replaced the o-rings and gasket. The tractor will now not leak and run but it will not throttle up or down instead it runs at a high idle. My father replaced the o-rings and gasket years ago and he had the same problem but he can't remember how he fixed it. Any help would be nice. Thanks
   / MF 35 Diesel CAV Pump #2
Were any changes made to metering valve control rod length, hopefully was left alone. Also need to keep spring position in gov arm and throttle lever in original holes. Make sure metering valve moves freely or governor control will be lost, it must not stick at all and have only the rod moving it on, stop bar to shut it down.
Thanks for you advice. I'm going to work on it again tommorrow since my father and i work on it all day today.
   / MF 35 Diesel CAV Pump #4
You may well find when you take off the top, that the spring is off, or the rod (bar) is not moving. you should not be able to lift the lid right off, if so the spring is off the lid.
Water in the fuel has always been a killer for CAV pumps.
We got it running right. We had the spring in the wrong hole on the tombstone. Thanks for your help.
   / MF 35 Diesel CAV Pump #6
That's good to know, :thumbsup:
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
(INOP) 2022 JLG R3246 ELECTRIC SCISSOR LIFT (A51247)
(INOP) 2022 JLG...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
WOODS RC60.20 LOT NUMBER 51 (A53084)
WOODS RC60.20 LOT...
