MF 35 cutting off
/ MF 35 cutting off #1
swgamf35
Moultrie, Ga
Massey ferguson 35
My Massey Ferguson 35 is cutting off every time I run over uneven time it just starting to do this today? I put a fuel lifter pump on it about 8 operating hours ago and I am wondering if this is a problem that would be caused by a faulty pump?
/ MF 35 cutting off #2
these were designed to be run on a gravity feed system.
if you indeed have fuel to the carb.. check the float and needle. sometimes the float hinge is bent or damaged and makes the flaot hang up.. either closed or open.. thus starving or flooding the machine. both will stall it.
/ MF 35 cutting off #3
G'day is this a petrol or diesel model, I am guessing that it is diesel if you put a lift pump on it.
Check for fuel flow at the tap as there should be a small screen inside the fuel tank on the fuel tap, if fuel flow is no good then you will have to remove the tap to clean. Also how high is the fuel level??
Jon
2013 Mercedes Benz GL 450 4 Matic AWD SUV (A64557)
2013 Mercedes Benz...
CLUBCART CART (A66091)
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
SHOPBUILT MESH BOTTOM TRAILER (A64278)
SHOPBUILT MESH...
