MF 31 sickle bar mower - Hinge bushing 581324M1
   / MF 31 sickle bar mower - Hinge bushing 581324M1 #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Getting down to the last few details to get my MF 31 sickle mower rebuilt. If you ignore all the problems, it's in real nice condition!
My hinge bushing is no good, and the only replacement I can find is $80 on eBay. The bigger hinge bearing uses a split journal bearing, like on a connecting rod. The smaller hinge looks like it's fabric reinforced. (?).
Its item#48 in the AGCO diagram.
375250d1400124999-mf-31-sickle-bar-mower-mf31-581324m1-agco-bushing-hinge
Is there a substitute for this bushing? Can it be made with plastic sheet?
   / MF 31 sickle bar mower - Hinge bushing 581324M1 #2
That joint doesn't move very often. I'd just rig up something with a large bolt/nut and pieces of PVC tubing cut to length.
Good luck.
Thanks Flusher. Thats a good idea, a split PVC pipe, will be just fine. Agreed, this joint is no big deal. It will move more if I add a hydr. cylinder to lift it over stumps?.:cool:
Hey Flusher, can you tell me the length of the PTO shaft? The distance from the shear pin to the tractor PTO. I need to order a shaft but forgot to measure the length last time I was out there and its 125miles away. I really appreciated your help along the way, anxious to get mine running.
   / MF 31 sickle bar mower - Hinge bushing 581324M1 #5
Nylon might stand up better than PVC, but it might be harder to get in the diameter you need?
   / MF 31 sickle bar mower - Hinge bushing 581324M1 #6
30 inches from the shear pin to the end of the pto U-joint on the mower end with the pto shaft fully retracted.
Good luck
Yes Nylon would be better, buy pretty sure Flusher's right that joint doesn't do much. If PVC or whatever (rolled up strips of 5-gal bucket etc?) wears out then I'll know to look for something tougher. Maybe "when" I add a hydr cylinder to raise it over stumps then I'll have an opportunity to wear it out (luckily my tractor has rear hydraulics).
OK Flusher, orderig a PTO shaft that is 30 inches retracted, Thx very much!
   / MF 31 sickle bar mower - Hinge bushing 581324M1 #8
I normally order somewhat oversize pto shafts (maybe 6-12 inches longer) and then cut the shaft to fit the implement.
Couldn't find a PTO drive that went to 1" shaft with 1/4" shearbolt. Since I have the mower half, I bought a the tractor half on eBay. I don't know what it's like inside, and assume I'll have to fabricate the 7/8 x 3/4 rectangular socket part. How much engagement do you think it needs? The shearbolt is only 1/4".
   / MF 31 sickle bar mower - Hinge bushing 581324M1 #10
A Nylon bushing would be simple to make on a lathe.
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
2021 JOHN DEERE CP690 LOT NUMBER 196 (A53084)
2021 JOHN DEERE...
JOHN DEERE 54D LOT NUMBER 162 (A53084)
JOHN DEERE 54D LOT...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
