MF 30 Industrial Hydraulic quit. please help
   / MF 30 Industrial Hydraulic quit. please help #1
georgia088
Thomaston, Georgia
Mf 30?
Hello all.
My MF 30 Industrial's hydraulics just quit. I was digging with the backhoe under normal conditions, and all of a sudden I just felt the pressure quit in the controls. Nothing hydraulic would work any more. I didn't see any major leaks (I have a few small leaks that I have had a while, but nothing major). I don't know a lot about hydraulics, but could anyone point me in a direction of what I could check?
Thanks!
Pumpdriveshaft splines stdipped ?
Ok. You were spot on. BUT... the shaft and coupler are both stripped out. My problem is i'm nit sure how the coupler comes off. I hace the pump side off. The shaft just pulled out if coupler. However, the coupler is still on shaft from other side. Please tell me it comes off and isn't made on to the shaft? Also, can you buy just the shaft that comes out of the pump? Or, do you have to replace the entire pump?
Thanks!
   / MF 30 Industrial Hydraulic quit. please help #5
Thanks!
Try to turn the shaft in the same rotation of the engine to unscrew from the frontpulleyadaptorplate.
2006 MACK CV713 KILL TRUCK AND TRAILER (A52472)
2006 MACK CV713...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
378639 (A51573)
378639 (A51573)
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
