MF 285 Steering Problem Question
/ MF 285 Steering Problem Question #1
weco100
I've got a MF 285 that the tie-rod end has separated & come off of the ball. Can a new tie-rod end be welded to the cylinder or do I have to replace the cylinder?
Thanks
/ MF 285 Steering Problem Question #2
Most are threaded on that I've seen to allow an easy replacement!
Thanks Art...just went out & looked at it & the tie-rod end is welded (I believe originally) onto the back of the cylinder.....the tie-rod end on the piston shaft appears to be part of the shaft.
To clarify, this is a tie-rod end on one of the 2 hydraulic cylinders and not that mount to the tie-rods...
/ MF 285 Steering Problem Question #4
If the cylinder still works correctly, why not see if it can simply be rewelded? I've never welded on an assembled cylinder and not sure it can be done, but would ask that question before I priced a new cylinder.
(INOP) 2006 INTERNATIONAL 7400 DUMP TRUCK (A65057)
(INOP) 2006...
2018 Mazda 6 Sedan (A66738)
2018 Mazda 6 Sedan...
FUEL TANK (A68842)
FUEL TANK (A68842)
2003 Sterling L7500 S/A Day Cab Truck Tractor (A66736)
2003 Sterling...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
X (A68191)
X (A68191)
