MF 285 Steering Problem Question
   / MF 285 Steering Problem Question #1
weco100
I've got a MF 285 that the tie-rod end has separated & come off of the ball. Can a new tie-rod end be welded to the cylinder or do I have to replace the cylinder?
   / MF 285 Steering Problem Question #2
Most are threaded on that I've seen to allow an easy replacement!
Thanks Art...just went out & looked at it & the tie-rod end is welded (I believe originally) onto the back of the cylinder.....the tie-rod end on the piston shaft appears to be part of the shaft.
To clarify, this is a tie-rod end on one of the 2 hydraulic cylinders and not that mount to the tie-rods...
   / MF 285 Steering Problem Question #4
If the cylinder still works correctly, why not see if it can simply be rewelded? I've never welded on an assembled cylinder and not sure it can be done, but would ask that question before I priced a new cylinder.
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2018 JLG 2632ES 26ft Electric Scissor Lift (A50322)
2018 JLG 2632ES...
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
PT 8' Offset Disc (A50121)
PT 8' Offset Disc...
