Oil & Fuel MF 2675 Fuel Guage reading wrong
   / MF 2675 Fuel Guage reading wrong #1
Grantp
Mt. Elgin, Ontario
Massey Ferguson 2675 1983
I have a 2675, perkins 6.354 engine (just rebuilt) runs fine - but the fuel guage reads empty when half full, and just under half when the tank is topped up. All other electrics seem fine. Any suggestions on where to start troubleshooting
   / MF 2675 Fuel Guage reading wrong #2
At the sender.
Okey dokey - any clues as to what I should look for - when full should it be a specific voltage or amp reading? All wires appear to be OK, and connections are tight.
Thanks.
Grant
   / MF 2675 Fuel Guage reading wrong #4
G'day Grantp.
Remove the sender and bend the float arm down say two inches and try that and see if it is more accurate if not fit a new sender or do as most others do, Cut 18 inches of the end of mums broom and drill a hole in it ,fit a string loop and hang it up near the diesel bowser No electrics required and guaranteed to work EVERY TIME :dance1: .
Have a great day .
Regards.
Hutch.
G'day Grantp.
Have a great day .
Regards.
Hutch.
Thanks Hutch - I can't buy into the broom handle idea - too heavy, I use a 3/8" dowel painted black! So far, so good, but as the tractor improves with time (mine!) I'm trying to get most features working. I will try the float arm trick as soon as I finish the horse shelter. Thanks for responding! All the best and Good on ya!
7021 (A50322)
7021 (A50322)
2022 JOHN DEERE 6140M LOT IDENTIFIER 174 (A53084)
2022 JOHN DEERE...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
2019 Hustler Super Z 60in Zero Turn Mower (A51691)
2019 Hustler Super...
