3-Point Hitch MF 2660 3 pt. lift will not operate
   / MF 2660 3 pt. lift will not operate
Yep. Could very well be [bent]. It is going to be hard to get in there to get enough visibility to find out. Is yours a cab or platform model ?
   / MF 2660 3 pt. lift will not operate #22
I have a platform tractor.
If the problem is interference inside the bore in the "hydraulic lift cover" that the control tube and rod pass through - and that is the most logical conclusion I can come up with - or which otherwise requires me to raise the cover to get into the internals then it is a job well beyond my means!
If the problem is interference inside the bore in the top cover that the control tube and rod pass through - and that is the most logical conclusion I can come up with - or which otherwise requires me to raise the top cover then it is a job well beyond my means!
You and me both ! I'd hate to have to dig in there even if it is "just" under the seat sheet metal and not internal to the chassis.
Mine is platform also. It is a "low profile" model but in these tractors that just meant lower diameter rear tires, some fender and floor features, one less step climbing up to the seat and few if any real serious mechanical differences.
2006 Ford F-550 4x4 Flatbed Truck (A50323)
2006 Ford F-550...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52748)
2022 JCB 3TS-8T...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
