Oil & Fuel MF 261 Injector removal
   / MF 261 Injector removal #1
bobstractors1
Elmo, TX
Lots
Team
I have a Massey 261 and have a injector pump problem. Need to remove pump.
My question is all lines removed , face plate on timing cover removed.
3 bolts on front of pump behind timing cover removed.
Now what ? pump wont just pull out
Thanks for any help
   / MF 261 Injector removal #2
Did you remove bolts from drive gear to pump shaft? Three bolts hold gear to shaft with a line-up pin. Tight fit between gear and shaft but they usually pull out with little effort.
yes did all that , thanks MFICAT
I think after studying it I just need to wiggle / pull it harder. I was waiting until the new one arrives before working more on the pull.
   / MF 261 Injector removal #4
Please let us know how things go. I could have the same problem at any time.
Army Semi Trailer (A50774)
Army Semi Trailer...
Corn Reel (A50514)
Corn Reel (A50514)
2007 International 7600 Tri-Axle Dump Truck (A50323)
2007 International...
10' Poly Feed Trough (A50515)
10' Poly Feed...
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
