Mf 2605 wont start
/ Mf 2605 wont start #1
vineyardkeeper1
Eastern NC
mf 135 mf 1643L mf 2605 ,4010 kaw mule,1972 chisol ryder grape harvester
Mf 2605 been sitting up for four mths went to start up and it cranked ran for about ten minutes then slowly died down then stopped
/ Mf 2605 wont start #2
check your fuel filter and the tank
/ Mf 2605 wont start #3
It's been sitting all winter. If untreated it may have gelled. Consider draining the tank, adding fresh fuel, and purging fuel lines.
/ Mf 2605 wont start #4
Sure sounds fuel related. Assuming "Eastern NC" is North Carolina, did that area have a recent cold snap with snow?
Depending on the source of info, diesel (summer, untreated) :
Cloud Point 32 deg f
Cold Filter Plug Point (CFPP) 10-15 deg
Gel Point 0 deg
Bio diesel will be less cold tolerant.
So at 10-15 degrees your filter could clog up.
These numbers vary considerably when "researched". The numbers I decided upon may, or may not, be entirely accurate.
/ Mf 2605 wont start #5
I just bought diesel yesterday at our Exxon and I saw a tag on the pump saying that it's "Bio-diesel" now. Our climate rarely sees cold weather, but we have had light frost at times in the winter. Gone within a few hours after sun rise; but should I be concerned enough to start adding additives to it?? I sure don't want to experience any of the problems that you minus zero folks have reported.
Thanks for any advice. Greg
/ Mf 2605 wont start #7
U BETTER get an additive..
Not trying to start a fight w anyone BUT.. as someone who knows, I’ve seen Bio start to “gell up” after a week of sitting in an unused tractor.. & I had to do minor surgery to get the tractor back running..
/ Mf 2605 wont start #8
BIO will jell a whole lot faster that #2 diesel
when its cold or starts to cool off TREAT your
fuel BIO save your self a lot of head aches
I know that the guys running veggie oil {BIO} had
to start their vehicles on diesel warm up then switch
over to bio then before shutting off switch back to
diesel or it would gum up the works
willy
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
INSPECTION (A65563)
INSPECTION (A65563)
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
