MF 2605 PTO
   / MF 2605 PTO #1
forestb69
2605 massey
Ive got a 2605 with FEL. My PTO has quit working, it has the single stick under left leg that says off-on. All hydrualics are working fine but I cant get the PTO to engage! Is there a clutch to adjust maybe?
   / MF 2605 PTO #2
Can you shift gears with the engine running? if the transmission stops using the clutch then the PTO should also be stopped. If both are moving and you grind gears then yes it sounds like a clutch issue. Not sure if there is an adjustment.
this may or may not be a help to you, but one way I tell if the PTO clutch is releasing or stuck is this: With the tractor switched off and the key in my pocket, I take a long pto shaft and hook it to the PTO on the tractor. I then support it so it is level and square with the tractor. I then wire the clutch pedal to the running board down as far as it will go with the pto lever engaged. next try turning the pto shaft out on the end with a bar or something that will give you leverage. I have freed up stuck pto clutches like that, and sometimes that don"t work either. I wouldn"t put a lot of power in trying to turn it like this. You may get hurt or damage something. The other way is to place a pipewrench or bar,(something about 3 or 4 foot long) At an angle like say 10:00 position,on the end of the same long pto shaft and hang a big weight on the end of the wrench/bar. then go depress the clutch slowly and see if it will release, dropping the heavy weight. (Keep the kids and dogs away from all this!)This may not help you out, but it gives you more information to research your problem.
Or you visit youtube for video guidance... I would also recommend good manuals but for now if you try this and it doesn;t work then we'd switch to manuals. Good Luck
   / MF 2605 PTO
The tractor cranks , runs, shifts, hydyraulics all work. PTO output shaft spins freely by hand, it just wont engage with the lever. really dont even feel like its even trying to engage a gear inside at all.
   / MF 2605 PTO
   / MF 2605 PTO #5
Sounds like the roll pin is broken in the shifter handle. Maybe the shift pawl is broken inside the transmission. Take the floor board up, drain the oil out, and take the side cover off. That's the only way to know for sure. I don't think it's the clutch, because your hydraulics are still working.
KSI Conveyor (A52748)
INSPECTION (A51572)
INSPECTION (A51572)
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
