MF 255 Questions on Hyd System and Diff lock
   / MF 255 Questions on Hyd System and Diff lock #1
Morty255
Zeeland, Michigan
Massey Ferguson 255
I have searched but not able to find what I am looking for. I have an oil leak on the bottom where I believe a filter goes (plate with 3 bolts) for the hydraulic system. I can't find anyone who sells a gasket for that, does it not take one? The differntial lock pedal is also locked, won't move. I spayed some lube on it hoping it will free up, any other advice? Thanks
   / MF 255 Questions on Hyd System and Diff lock #2
Hey Morty, I'm not sure I will be of great help here, but I will offer what I can... On your diff lock, are you saying it is locked down in the engaged position or that you can't get it to move down and engage? My Massey has a small foot pedal that I have to hold down pressure on to lock the diff. It does not engage easily, and sometimes I have to rock the tractor back and forth to get it to "drop in". As soon as I remove my foot, a spring will unlock the diff.
It won稚 engage, I can stand on it, rock the tractor and the pedal won稚 move. I had another 255 and I know what you mean by rocking it.
Thanks for the reply.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
378635 (A51573)
378635 (A51573)
