mf 25 disc parts
   / mf 25 disc parts #1
pv31
ontario
mf 50hp
Hey
I've read previous posts on mf 25 disc replacement parts. So far I know that the bearing casing and bearing spacer spool are available from agrisupply.
I'd like to know whether the following parts I list, are also replacements for the disc.
Bearing casing - 28211 (known)
Bearing Housing, Disc Bearing Housing, Disc Boxing | Agri Supply, 28211, Tillage
Bearing Spacer Spool - 28210 (known)
Bearing Spool, Bearing Spacer Spool, Spacer | Agri Supply, 28210, Tillage
starting unknown list
Bearing Plain Spacer Spool - 31717
1 x 7-1/2 Bearing Plain Spacer Spool
Disc Axle - 28938
1 x 34 Disc Axle-Replacement Disc Harrow Axle | Agri Supply #28938
Plain Disc - 34826
18 Inch x 3MM Plain Disc Harrow Blade | Agri Supply #34826
Notched Disc - 30954
http://www.agrisupply.com/mm-sch-concavity-notched-disc-blade/p/30954/&sid=&eid=/
Axle Bumper Washer - 40255
http://www.agrisupply.com/disc-harrow-bumper-washer/p/40255/&sid=&eid=/
End Washer - 36069
http://www.agrisupply.com/end-washer-for-disc-harrow-axle/p/36069/
Also, I understand that the bearing housing and bearing spacer spool can be replaced, but what if the part from the frame that holds the bearing housing is damaged? Is that something that can be fixed?
Appreciate any input.
Thanks
   / mf 25 disc parts #2
Hey
Disc Axle - 28938
Plain Disc - 34826
Notched Disc Harrow Blades, Disc Blades, Disc Harrow | Agri Supply | Agri Supply
Bumper Washer-Disc Harrow Bumper Washer
End Washer - 36069
1 End Washer For 1 Disc Harrow Axle | Agri Supply 36069
Thanks
I have oem bearings for the MF 25 disc from a salvage job.
816-277-4968
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
UNUSED AGT 54" EXCAVATOR HYD BRUSH CUTTER (A51248)
UNUSED AGT 54"...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
