MF 240 Top-n-Tilt
   / MF 240 Top-n-Tilt #1
Tabasco Jack
Drakewtown, GA
MF 240 & Ford 1710
After lots of searching I can't find an answer. Is it possible to add hydraulic remotes to the 240 without having to use a divertor valve? What good is a hydraulic top link when you have to switch off the 3PH?
Anybody got one installed?
   / MF 240 Top-n-Tilt #2
I had a MF240D with two remotes, used one for a hydraulic toplink. Did not have to turn off the 3PH.
   / MF 240 Top-n-Tilt #3
Adding another hydraulic pump is the way to go if you need to operate the 3pt, and the remotes at the same time.
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
