Grading Mf 2340 Blade
/ Mf 2340 Blade #1
DougM
Northeast Ohio
GC 2310
I would like to know if some one could PM me with prices of
Mf 2340 Heavy Duty Blade ( 60 in )
Front Quick Hitch System /forums/images/graemlins/crazy.gif
I would like to have a front snow blade on my gc 2310
I have been to two deelers???/
one told me I did not want these as they cost to much
the other told me they would not fit on my GC 2310..
as the front end loader and the backhoe were mounted
permently... /forums/images/graemlins/shocked.gif
DougM
/ Mf 2340 Blade #2
Doug,
I've noticed your recent posts regarding wanting a snow blade to attach to your FEL, but didn't post a reply because I really don't know the first thing about pushing/plowing snow.
However, I've determined that I'm going to rig up a way to use a landscape rake mounted to my FEL to help clear weeds out of the pond. A speeco or JD quick hitch that will attach to the landscape rake, with mounting plates fabricated and welded to it so I can attach it to the quick-attach on my FEL just as I change out from bucket to forks.
I'm not sure about what's available for the GC, but the quick-attach for my FEL was less than $200, and requires removing the lower pin on each side to swap implements. If this is feasible you should be able to use a conventional 3ph blade on the front. And this has been done by other TBNer's by the way. I was sitting around one day thinking about how smart I was to think about this, and when browing the forums I saw a thread with pictures where it was in use! Can't find it right now, but if you are interested it's out there.
/ Mf 2340 Blade #3
Doug,
Massey's website lists "dozer blades" as one of the attachments for the GC2310. Hard for me to believe that FEL and BH are permanently attached. Too many folks like you that want to attach other stuff...
Here's their website: Massey GC2310
/ Mf 2340 Blade #4
The "dozer blade" mentioned is mounted with the same quick attach front end as my snowblower. The idea is so that you can easily swap between implements.
Doug, are you wanting to keep the loader on so that you can push and lift the snow around as opposed to using the scraper on the back in combination with your loader (after you remove the BH of course ;-)
Just curious...Henry..
/ Mf 2340 Blade
I am wanting to have the snow blade (plow) attached to the frontend loader.
The dozer blade listed for the mf 2310 best price I can find is $ 1770.00 a little high.
DougM
/ Mf 2340 Blade #6
</font><font color="blue" class="small">( I would like to know if some one could PM me with prices of
DougM )</font>
Evidently I have executed ruinous damage to my little red 2310. I hereby publicly confess that I have removed the permanently mounted backhoe twice, once for fun and once so that I could attach the GearMore G-series tiller.
BTW, if you pop for a G-Series on this tractor, plan on shortening the PTO shaft by at least 3 1/3 inches. (I suppose you could ask your dealer to perform this surgical procedure, but why give him a chance to screw things up again?)
Anyway I'm a happy 2310 owner. Tough little machine (so far).
/ Mf 2340 Blade #7
Looks like some of these dealers should read their own literature -"quick attach - easily removeable", etc...doesn't sound too permanent to me.. /forums/images/graemlins/grin.gif
Oh I get it---it is permanently on there while you are using it! I suppose that is a good feature!!.. /forums/images/graemlins/wink.gif
Henry..
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A65579)
New/Unused AGT...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
17601CFL (A59228)
17601CFL (A59228)
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
