MF 231S tachometer not working
/ MF 231S tachometer not working #1
def38
Platinum Member
woods and mountains of Alabama
M-F 231S
Started the engine today and the tech needle was intermittent. Shortly afterwards, the tach went to zero with the engine at idle. I wiggled the tach cable jacket to no avail. What's wrong?
I'm stumped. :confused::anyone:
/ MF 231S tachometer not working #2
I beliefe you altenator light is also not working ?
Check if altenator is charging. If not ....repaire or replace it.
The M-F 231S tachometer is not actuated off the alternator. It is a mechanically driven tach using a speedometer style cable off the front of the engine (camshaft?). The tachometer is clockwise rotation. BTW, the alternator light works fine as does the oil pressure light.
/ MF 231S tachometer not working #4
Hello Fuddy, Yup, that's the tach/hour meter. I'll have to get all greasy and remove the cabel and see what's goin' on. Wonder where I can get a new cable?
BTW, that seems pretty pricey for a new tach dontcha think?
/ MF 231S tachometer not working #6
Test the cable......then check the angledrive.....remember to check the cable tips for squereness
So, today, I removed the tach cable completely and inspected it for condition. There was plenty of oil in the jacket so, I looked at the squared ends. They are getting rounded off due to age and wear. I did get it to work but, I have a new cable on order ($10.00, free shipping). Also, my tach shows the Perkins diesel idling at almost 1000 RPM, a bit fast. When I get the new cable and install it, I'll be in the neighborhood of the injector pump so I'll turn the idle down a bit. Does 800 RPM sound about right?
Hmmmm….looks like you missed the "r".
On another subject, today I had to discard all my Naval oranges due to old and spoilage. They were from So. Africa.
BTW Dirk, what kind of tractor is your favorite?
/ MF 231S tachometer not working #10
I am a tractormechanic and work on all.
/ MF 231S tachometer not working #11
But to answer you Q...That make and model with the agent on your doorstep !
If its a Case and you have to drive 200 km to get a v-belt ????
If its a Same and u can drive it into the workshop !!!!
So, I received my $10.00 USD (free shipping) new tachometer (actually they call it a tractormeter) cable. I removed the OE cable and the engine side ferrule fell off. It was shot. I installed the new cable noticing it is much more flexible (whaddya expect for $10.00) and the inside drive cable is a bit longer. While I was on the port side of the engine, I reset the engine idle stop screw on the injector pump to an idle speed of 775 RPM. Next, I installed a fuse box so that I can add some electrical circuits for a rear cigarette lighter socket and rear floodlight for nighttime work. Next, I'll drill two 1/2" dia. holes and install bat handle switches to control the lights. Can't wait to do some nighttime plowing.
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
2013 PROFAB 200BBL CRUDE TANKER (A65643)
2013 PROFAB 200BBL...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
2015 Ford F-150 Pickup Truck (A62613)
2015 Ford F-150...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
