MF 231S tachometer not working
   / MF 231S tachometer not working #1
def38
Platinum Member
woods and mountains of Alabama
M-F 231S
Started the engine today and the tech needle was intermittent. Shortly afterwards, the tach went to zero with the engine at idle. I wiggled the tach cable jacket to no avail. What's wrong?
I'm stumped. :confused::anyone:
   / MF 231S tachometer not working #2
I beliefe you altenator light is also not working ?
Check if altenator is charging. If not ....repaire or replace it.
The M-F 231S tachometer is not actuated off the alternator. It is a mechanically driven tach using a speedometer style cable off the front of the engine (camshaft?). The tachometer is clockwise rotation. BTW, the alternator light works fine as does the oil pressure light.
   / MF 231S tachometer not working #4
Hello Fuddy, Yup, that's the tach/hour meter. I'll have to get all greasy and remove the cabel and see what's goin' on. Wonder where I can get a new cable?
BTW, that seems pretty pricey for a new tach dontcha think?
   / MF 231S tachometer not working #6
Test the cable......then check the angledrive.....remember to check the cable tips for squereness
So, today, I removed the tach cable completely and inspected it for condition. There was plenty of oil in the jacket so, I looked at the squared ends. They are getting rounded off due to age and wear. I did get it to work but, I have a new cable on order ($10.00, free shipping). Also, my tach shows the Perkins diesel idling at almost 1000 RPM, a bit fast. When I get the new cable and install it, I'll be in the neighborhood of the injector pump so I'll turn the idle down a bit. Does 800 RPM sound about right?
Hmmmm….looks like you missed the "r".
On another subject, today I had to discard all my Naval oranges due to old and spoilage. They were from So. Africa.
BTW Dirk, what kind of tractor is your favorite?
   / MF 231S tachometer not working #10
I am a tractormechanic and work on all.
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
71052 (A49346)
71052 (A49346)
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
