MF 231S air in fuel system
   / MF 231S air in fuel system #1
fireman4074
MF 231S
I have MF 231S. I replaced the fuel filter. I used the prime pump on opposite of engine to full filter with diesel. I also breed line and call myself getting air out of line. It cranked but it still have air in line. How can I bleed rest of air in line out? It will go died but it will crank after sitting a few minutes. It’s also start blowing blue smoke which it never done that before. The red arrows are lines that bled. Am I missing something? I have video but not able to upload.
   / MF 231S air in fuel system #2
I have a 231s as well. I bought a new filter but have not changed it yet for fear of this same issue.
   / MF 231S air in fuel system #3
You have to bleed all three injectors on the head, crack all three lines, crank engine until you get fuel at all three, then tighten them.
Ok once fuel come out do I need to shut engine off.
   / MF 231S air in fuel system #5
Yes, should have said to stop cranking, tighten the lines, the try and start it. I've had it pick up on 2 cylinders then 3rd picked up after a bit.
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53472)
2020 Westfield MKX...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
2012 CHEVROLET 3500HD SILVERADO LS DUALLY TRUCK (A51247)
2012 CHEVROLET...
