MF 2310 and Kubota BX Tire/Wheel compatibility
   / MF 2310 and Kubota BX Tire/Wheel compatibility #1
mvanhaerents
S.E. Michigan
Deere 4410
Does anyone know if the wheels and tires from a Kubota BX2200, BX23, or BX24 fit onto a 2310? The tires look to be the same size, but I am not sure about the wheel's lug pattern and back spacing. It is much easier to locate replacements on the Kubota side of things than the MF.
   / MF 2310 and Kubota BX Tire/Wheel compatibility #2
Good question, I'll bet money the don't interchange.
   / MF 2310 and Kubota BX Tire/Wheel compatibility #3
I wouldn't! I'd just do some investagating as they might fit. Got a BX in your neighborhood?
The front tires on the 2310 are 18x8.5x10 while the kubota's are 18x8.5x8. I'm not sure if the front axle requires a 10" rim, but I'm guessing it does based on the 8" size being a more widely available tire.
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
