MF 231 - Will a 230/240 shop manual work?
   / MF 231 - Will a 230/240 shop manual work? #1
Rford
KC
1966 Ford 2000 Diesel 8sp
First off, anyone thinking about buying a MF 231 should check out the parts availability for this tractor. The on-line sources rarely show a 231 application. The parts list just jumps right over the 231. And if you aren't knowledgeable, like me, you don't know if a part for a 240 or 230 would work on a 231. So that's frustrating. I like the tractor, I just wish it had some parts support. But that's what you get for buying a Polish built tractor, I guess.
Anyway, enough of that rant. I can buy Clymers shop manuals, and a lot of others, for the 230, 240, etc. but, of course, not for the 231. Does anyone know if for general stuff if one of these manuals would be close enough for general work? I'm getting ready, depending on parts, to try to do an in frame rebuild and while I have a downloaded Perkins 3-152 engine manual I don't have a shop manual for the tractor itself. It's probably pretty self-evident how the gas tank, radiator, etc. comes off but I'd just feel better taking a look at a manual that was at least for a similar tractor.
Any guidance would be helpful. But I don't want to buy a $100 shop manual if I can help it.
   / MF 231 - Will a 230/240 shop manual work? #2
Did you check AGCO for manuals?? Manuals are readily available. Look here...
http://www.agcopubs.com/massey_ferguson/parts_book/multiple/651602m95/231
http://www.agcopubs.com/massey_ferguson/operator_manual/english/1856911m2/231
http://www.agcopubs.com/massey_ferguson/service_manual/english/1449233m92/231_261_tractor_assembly_
http://www.agcopubs.com/massey_ferguson/service_manual/english/1449233m2/man_serv_mf_231_261_trac
Also, MF should still support that tractor, as it is a bare bones simple utility tractor. Nothing wrong with where it is built either.
This will be the best money that you will ever spend, especially if you plan on keeping it. The aftermarket manuals are good for leveling a workbench off, not too much else.
Still supported, just checked agcopartsbooks.com
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/651602
Do you have a GOOD dealer nearby?
   / MF 231 - Will a 230/240 shop manual work? #3
Yup, that was a pretty good tractor. If you don't want to spend the money for a good manual, don't buy any manual. The factory manual is the best you're going to get. Anything else is just a waste of money.
That tractor is still pretty new as far as tractors go. Aftermarket parts would still be a way out. But, that means you should be able to walk into any decent AGCO dealer and get your parts.
Thanks. It's the aftermarket lack of parts. The dealer is 70 mikes away. If that is a downloadable service manual, for $40 or so that's OK, but it looks like its going to be a $100. I suppose its worth to keep the thing running and maintained properly.
I found a good after market outfit--MADISON TRACTOR. LOTS OF PARTS FOR THIS TRACTOR AND GOOD SERVICE.
   / MF 231 - Will a 230/240 shop manual work? #7
   / MF 231 - Will a 230/240 shop manual work? #8
Have a sun shade that I took off. Is not perfect but is complete. Will sell cheap.
   / MF 231 - Will a 230/240 shop manual work? #9
The 231 was built in a different factory (Poland) than the 230/240 (England) therefore while there are similarities, different components from a different manufacturer were used in each tractor eventhough the brand name MF is the same, thats where it ends.So, suggest you visit a good MF dealer for the proper manual.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2020 JOHN DEERE 6145M LOT NUMBER 79 (A53084)
2020 JOHN DEERE...
Bushog 6ft Disk Mower (A51573)
Bushog 6ft Disk...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
