MF 230 low oil pressure
   / MF 230 low oil pressure #1
frankroberts
MF 50
The oil pressure is about 35+ lbs on my MF 230 when the engine is cold. But as the engine warms the oil pressure goes down to 5 lbs. It's a 4 cylinder gas continental engine. What are the reasons this could happen. Bad main bearings? Bad oil pump? Bad rod bearings? Are the rod bearings lubricated by 'splash'?
What would be a normal oil pressure for this tractor. The hour meter on this tractor was not operable for some time and the serial number plate was removed by some earlier owner.
Thanks for the help.
frank
   / MF 230 low oil pressure #2
G'day Frankroberts.
First thing to do is change the engine oil and filter,if this works thats good ,if not,
Remove the sump and first check the running clearance of the crankshaft connecting rod bearings then the main bearings If they are good check the lube oil pump.
Happy days.
Hutch.
Is it possible to check the main bearings without removing the engine?
Thanks for any help.
frank.
   / MF 230 low oil pressure #4
frank
Rods and mains are presure lubed. These Continentals have a weak oil pump, in my opinion.
Check the oil pump clearances and make sure the relief valve is not stuck open or has a damaged spring.
If those things are good than suspect the main bearing clearance. You can check those qwith Plastigage in frame.
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
2025 12v Diesel Pump, Hose And Nozzle (A50323)
2025 12v Diesel...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
