3-Point Hitch MF 230 3 point hitch
   / MF 230 3 point hitch #1
Mouche3
Deville, Louisiana
MF 230
Hey everyone, this is my first post. I have a 230 massey that the 3 point hitch doesnt work right on. With anything hooked up to it with the draft control lever in the most upright position and the position control lever in the most up position you can put any amount of weight onto it and it will slowly go back down to the ground, in seconds. It also has a hard time picking up heavy implements. Any help would be greatly appreciated.
   / MF 230 3 point hitch #2
Sounds like its in your draft control. Im working on one as we speak. Im having to take the spring out and adjust there and also am having to replace the the seals in the piston. Not an easy job put you can do it if you have a shop work book. You will have to pull the lift section off the tractor.
   / MF 230 3 point hitch #3
G,Day mouche3. If you read my reply to sgblazer2 this will help. Regards Hutch.
Thank yall and where would i find a service manual for this tractor?
   / MF 230 3 point hitch #5
Talk to your local MF dealer if one is close, if not shop around on the internet. I have an I&T shop manual that some who have used both it and the original manufacturers manual say it lacks detail, and in some cases contains erroneous information. I haven't used mine for a major overhaul but did use it to fix a similar problem as yours on my 135. Followed the specs and tolerances in the manual and it fixed my problems.
   / MF 230 3 point hitch #6
There is another thread called "135 lift problems" on much of the same subject. Is there a special tool you need to adjust the main spring? Do you have to remove the spring? The manual shows it being adjusted in place with a tool FT 358 on my MF245 which I think is similar to the 230.
   / MF 230 3 point hitch #7
G.Day Joe.
The draft spring can be adjusted using the special spanner but the assembly has to be removed to set the spring tension first.
Happy Days .
Hutch.
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52141)
1999 KENWORTH W900...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
John Deere 24" Backhoe Bucket (LOCAL TOWNSHIP) (A50774)
John Deere 24"...
2024 John Deere 872GP Articulated Motor Grader With GPS Package (A52143)
2024 John Deere...
Army Generator (A50774)
Army Generator...
