MF 205 4wd engagement.......??
   / MF 205 4wd engagement.......?? #1
cansox12
Nevada County, NorCal
MF205= Hinomoto E184
Hi All ! let me first say " thanks to all of you that have the patience to answer some pretty ridiculous question's" These forums are the first place i go when researching a problem fix, or looking for critical information...Thanks
This leads me to my inquiry. I was recently gifted a mid-80's Massy Ferg 205 4wd. 6 speed h/l, front loader, box scraper, new tires, electrical system a mess, and fuel injection pump failure. No problem, paid $700 to have the pump rebuilt, during the rebuild I removed and rebuilt the entire elect system complete w/new temp gauge, LED charge and oil indicators, 2 speed 12vdc cooling fan(ford escort @the local wrecking yard) and newly fabricated dash/instrument cluster. Rebuilt fuel pump installed, all fluids (including the hydro-trans oil all 17 qrts) and filters replaced. Fire's up first time ....OK ....everything seems to function like it should, start moving some dirt and..........
Here is my current problem: 4wd is not engaging ?, where is the 4wd engagement lever and is there one? My diagnose of the problem so far (counting levers. from the steering wheel towards the rear, on the left hand side of trans) is, 1.pri H/L, lever 2.secondary H/L lever 3. Not sure...? 2 position lever doesn't feel like any kind of torque traveling through this gear set. At idle clutch out I can faintly feel the mesh of gears but dose not effect the drive train at all. Is This my 4WD.....??? please tell me I'm missing something stupid.
I do have a I/T service/repair maunal and no where can I find this lever, parts descriptions or exploded views....., google searched....., searched forums and read as many potential forum post's that might of been of help...
I would really appreciate any and all input from any and all of you.... Thanks
   / MF 205 4wd engagement.......?? #2
Can you post a picture of the levers? that might jog my memory.
I used 4WD a lot on my 240. :D
   / MF 205 4wd engagement.......?? #3
So now your posting "dirty" pictures too.:censored:;)
   / MF 205 4wd engagement.......?? #4
Yep, it sure looks like it. There is "no limit" on the dirty pictures that I have. :D
   / MF 205 4wd engagement.......?? #5
I have the same problem my 4x4 will not engage my lever is on left side by fender down is four up is two wheel drive I believe the problems in the transmission slide gear not engageing
   / MF 205 4wd engagement.......?? #6
Show us a picture of the front axle... The MF 205 was two wheel drive. The 205-4 was 4wd....
It could have the front driveshaft disconnected. Or the U joint could be history, or the shfter not engaging...who knows?
Sometimes I wonder if mine is engaged in 4wd. I know it has 4wd and the lever shows engaged, but it sure doesn't seem to be doing much.
What I do then is put the loader bucket flat on the ground so it will slide, then use the loader to lift the front end just clear of the ground, select a lowish gear, and let out the clutch just enough to see if the front wheels are turning under power.
So far, so good.
rScotty
1997 Freightliner FL60 Truck, VIN # 1FV3GJBC6VH725847 (A51572)
1997 Freightliner...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2017 JACTO ARBUS-1500 DIAM LOT NUMBER 66 (A53084)
2017 JACTO...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2020 KUBOTA RTV...
