MF 202 clutch problem
   / MF 202 clutch problem #1
Mf Bob
Massey Ferguson
Bought a work bull and am new to tractors.
Clutch was fine on first 2 days but gradually got harder and harder to push clutch pedal down.
Then I noticed it didnt fully release the transmission and tractor would creep forward with clutch "to the floor".
Checked free play adjustment and even after setting to very small free travel to get max motion on pressure plate fingers it still creeps with full travel on the pedal.
Any ideas out there on what's going on inside the bell housing?
Bob
   / MF 202 clutch problem #2
Bob
Hello, I regret to think that I buy a tractor with the embreague in its last hours, I believe that it will have to split its tractor and to replace the set, it is a quite simple work but it must be careful when separating the tractor in the middle, it is going to need two hydraulic jacks and one of them with wheels to move one of the parts of the tractor, I wish you luck in your task, greetings
Thanks for the thought. I am guessing it needs to be in a shop for that and not in my gravel driveway. Will start to look for places to send it
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
Knapheide Mechanics Body (A52384)
Knapheide...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
MASSEY FERGUSON 1135 TRACTOR (A51247)
MASSEY FERGUSON...
550 Tubes Grease Cartridges (A53117)
550 Tubes Grease...
