MF 188 (1979 not multi) water temp gauge
   / MF 188 (1979 not multi) water temp gauge #1
kostaschatzis
GREECE / ORESTIADA
MF 188 / FIAT 880-5
Hello Friends
I am here again as new MF owner for advices (thanks in advance)
Today i ve change the water temperature gauge , but the new one is different from the old, sorry for the question but is the gauge on photo correct?
thanks for the answers
   / MF 188 (1979 not multi) water temp gauge #2
Hello Friends
Yes....if your in Celcius country
DLLTekkers
i ve change the engine oils twice (because for about 2 years never the tractor was in a barn) 1st time after 2 hours of engine work, the oil that i used is 20-50 do you think is the correct ? The oil pressure gauge goes as the picture (red pencil) the temperature on my area is about 20C-30C (Greece) oil.jpg
   / MF 188 (1979 not multi) water temp gauge #5
Thats fine .
A blocked filter can give you even a higher reading on that gauge.
On idle it should be much lower
i ve change the oil filter once. With the tractor stopped and working the idle is on the middle of green , whith the tractor mooving and pressing full rpm for 1 km about goes as the picture.
Should i change the filter again?
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
Fire Truck (A51692)
Fire Truck (A51692)
