Oil & Fuel MF 180
   / MF 180 #1
cdog21
WI
Massey ferguson 180
I have a 68 Massey 180. My engine oil keeps overfilling as I run the tractor, and in a fairly short time.
Anybody run in to this problem before or have the solution ?
   / MF 180 #2
Check to see if your engine oil smells like diesel fuel. Sounds like the diaphragm is out of the fuel lift pump. When the diaphragm goes bad, it will leak fuel directly into the crankcase.
It's an easy fix, lift pump is external. Remove a couple of lines, a couple of bolts, clean the mating surface. Install new pump with gasket. You may need to purge the line of air, from the lift pump, to the first connection beyond the lift pump.
IIRC, I found an aftermarket pump for around $35.00 plus shipping.
   / MF 180 #3
If the supply pump does not repair the leak the injection pump may need resealed also. I've repaired several that were leaking at the drive hub, allowing fuel into the oil also..
2005 CHEVROLET EXPRESS CARGO VAN (A53426)
2005 CHEVROLET...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
PAIR OF FILING CABINETS (A53843)
PAIR OF FILING...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2012 Ford F-350 4x4 9FT Knapheide Flatbed Truck (A51691)
2012 Ford F-350...
