MF 165
   / MF 165 #1
CircleJFarm
A friend of mine has a 165 and the 3point lift arms will not operate up/down. Several years ago I purchased a TO20 with the same problem. I dropped the pump and replaced the relief valve. Could this be the same problem? Any help would be great!!
   / MF 165 #2
Could be, probably not though. Best to get a manual and do some tests. Same idea as your older tractor but a little more in depth. Some troubleshooting would give a better idea. Do the arms shutter at all? There is a round cover on the right side, if you drain a little fluid & open it you can manually run the pump so kinda test it. That will give you some direction if it's pump, lift cylinder or something else.
   / MF 165
I'll pull the cover and check. Thanks!!
1999 Sandbagger G-4 Hopper (A49462)
1999 Sandbagger...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
