Oil & Fuel MF 165 will only run for 10 mins
   / MF 165 will only run for 10 mins #11
Same thing was happening to an Allis Chalmers 180 diesel a neighbor owns, it wasn't getting used much and the bio diesel formed a black sludge that would clog up a screen on the bottom of the tank in 10-15 minutes of usage and would run the system dry. I cleaned the lines, washed out the tank several times etc and eventually it killed the pump which had to be rebuilt. I ended up replacing the fuel tank (as that is where the contamination kept originating from), all the filters and cleaned the lines real well and there hasn't been a problem since.
Neighbor was too cheap to replace the tank and instead insisted it could be washed out, was to cheap to add an anti-gel, power service or anything else to their farm tank and strangely enough there wasn't a problem in 3 other diesel tractors in use on the farm.
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
2259 (A58376)
2259 (A58376)
2248 (A58376)
2248 (A58376)
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
202482 (A54757)
202482 (A54757)
