MF 165 Hydraulic Leak
   / MF 165 Hydraulic Leak #1
Tatertot
MF165 and Case 485
The tractor started pouring hydraulic fluid from around the starter. Any ideas??
   / MF 165 Hydraulic Leak #2
How long have you had it? Is it coming from the starter hole or just in that area?
   / MF 165 Hydraulic Leak #3
is it a multi power ? there is a valve in the clutch housing, also a hydraulic pipe
It is coming from the starter hole and it does have multipower.
   / MF 165 Hydraulic Leak #5
Its most likely the input shaft seal, which is under pressure with multi power fitted, although it may be an o ring on the MP valve or a blown or loose hyd line, in any event you will need to seperate tractor at clutch housing to access. make certain it is an internal leak though before going to this stage, there are MP hydraulic lines just behind the starter on top of bell housing. Good luck
It is internal. I have a mechanic that is going to work on it this week. I'll let you know the outcome.
   / MF 165 Hydraulic Leak #7
thanks, would like to know outcome
2012 International 4300 Reefer Truck (A53472)
2012 International...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
