MF 165 Hydraulic Leak
/ MF 165 Hydraulic Leak #1
Tatertot
MF165 and Case 485
The tractor started pouring hydraulic fluid from around the starter. Any ideas??
/ MF 165 Hydraulic Leak #2
How long have you had it? Is it coming from the starter hole or just in that area?
/ MF 165 Hydraulic Leak #3
is it a multi power ? there is a valve in the clutch housing, also a hydraulic pipe
It is coming from the starter hole and it does have multipower.
/ MF 165 Hydraulic Leak #5
Its most likely the input shaft seal, which is under pressure with multi power fitted, although it may be an o ring on the MP valve or a blown or loose hyd line, in any event you will need to seperate tractor at clutch housing to access. make certain it is an internal leak though before going to this stage, there are MP hydraulic lines just behind the starter on top of bell housing. Good luck
It is internal. I have a mechanic that is going to work on it this week. I'll let you know the outcome.
/ MF 165 Hydraulic Leak #7
thanks, would like to know outcome
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2021 YANMAR VIO25-6A EXCAVATOR (A63276)
2021 YANMAR...
Wooden Chair (A64557)
213130 (A64276)
213130 (A64276)
2015 GMC Sierra 3500 HD 4x4 Crew Cab Flatbed Truck (A64556)
2015 GMC Sierra...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
