Mowing MF 1648 cranking trouble
   / MF 1648 cranking trouble #1
deepwaterwolf
Louisville, ms
Massey ferguson
While bush hogging I got on a stomp and choked the tractor down. Now the starter won't even try to crank. I have checked all the safety switches and I am not getting any voltage to the starter but the switches appear to ok.
   / MF 1648 cranking trouble #2
I wonder if you pulled a wire off somewhere near the lower portion of the tractor? It may have kept running as that circuit is only needed when starting?
It actually ended up being the battery. I have never seen a battery go bad like this one did. It gave no early warning signs as every battery I have ever had does. It was cranking good then Bam it would not do anything.
   / MF 1648 cranking trouble #4
Wow, glad you figured it out!
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
Ideal Applegate 180 gal Water Trough (A50515)
Ideal Applegate...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2018 Ford Ecosport (A50324)
2018 Ford Ecosport...
