Mowing MF 1648 cranking trouble
   / MF 1648 cranking trouble #1
deepwaterwolf
Louisville, ms
Massey ferguson
While bush hogging I got on a stomp and choked the tractor down. Now the starter won't even try to crank. I have checked all the safety switches and I am not getting any voltage to the starter but the switches appear to ok.
   / MF 1648 cranking trouble #2
I wonder if you pulled a wire off somewhere near the lower portion of the tractor? It may have kept running as that circuit is only needed when starting?
It actually ended up being the battery. I have never seen a battery go bad like this one did. It gave no early warning signs as every battery I have ever had does. It was cranking good then Bam it would not do anything.
   / MF 1648 cranking trouble #4
Wow, glad you figured it out!
2018 Jaguar XE (A50324)
2018 Jaguar XE...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
Sudenga 10-72 Swing Away Auger (A50514)
Sudenga 10-72...
PULL FLOAT AND CEMENT WORKING TOOLS (A51243)
PULL FLOAT AND...
