MF 1532 Will not start
   / MF 1532 Will not start #1
JonLaHon
Al
Massey Ferguson 1532
Can someone help me. I was bush hogging behind my house and the tractor died. The gauges went flat and the lights will not come on. Also when you turn the key the fuel pump will not come on. I found a connector that was loose under the tractor and do not know where it goes. It has two blue wires going to it and is a six pin connector in a rectangle shape. Can someone give me help?
   / MF 1532 Will not start #2
Probably the neutral saftey switch on the range shifter or gear selector. Mine has came off twice and it wouldn't start with no lights. One of the two times was yesterday. Both times mowing heavy brush and yaupon. Everything was fine until I shut it off for a break and then nothing when I hit the key. The loose wire can only fit a switch that is somewhere in the radius of the loose end. If there is 12 inches of loose wire............look in a two foot area around the point where the wire is secured.
hugs, Brandi
John Deere S780 Combine (A53342)
John Deere S780...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
JOHN DEERE 17P LOT NUMBER 227 (A53084)
JOHN DEERE 17P LOT...
