I have been trying to track down the following problem for about 2 years now... My tractor will start and run but after a few mins or half an hour it will stop... it might start right up or it might take a few times to catch... when I turn the key it will run and when I let go it will stop.... it sounded like I had a problem with the fuel solenoid so I removed it and the tractor ran fine... I replaced the fuel solenoid and the problem persisted.... it seems like the pull circuit is working properly but the hold circuit is either shorting out or has a broken wire.... I ran a wire direct from the battery to the hold circuit and the tractor works fine...I just have to disconnect it to turn it off... PITA. So I figured I would have a go at tracing the wire.. I removed the plastic dash and was undoing all the connectors and spraying with contact cleaner... (it was filthy under there)... I left the tractor running and was wiggling connectors when it suddenly died.... looks like it might have a bad engine stop relay.... anybody have any idea what the part number is for this?.... I would like to replace it but I cant find any info on it
