MF 1440 Hick-ups at high rpm
   / MF 1440 Hick-ups at high rpm #1
Task
My 1440 hick-ups or sputters at high rpm and puffs a tiny bit of blue, only at that time. What would cause that?
   / MF 1440 Hick-ups at high rpm #2
Is everything Kosher with the fuel supply system?:D
Hi Egon, Thanks for the reply. I 'm not much of a mechanic. I'm wondering if I put in an additive of some sort if that would solve the problem. I live on the Canadian Prarries. I filled it up with fuel at a gas station when I was bringing it home after purchasing it, the fuel looked kind of frosty, like the top of an A&W rootbeer mug. Any thoughts?
   / MF 1440 Hick-ups at high rpm #4
And neither am I.:eek: Putting the fuel additive in surely will not hurt. The warmer weather you are getting now might help if it is a waxing or water problem.:D
How often have you filled it with fuel?
That was fast, I've only filled it the one time, as I just bought it. Do you know what kind of additive to put in? (I don't wont to put the wrong thing in and make it worse. Thanks!
   / MF 1440 Hick-ups at high rpm #6
Go to one of your local truck stops and ask them as there are many different types and the one I use may not be available in your area. Do not use anything that has alcohol in it.
You might also want to change the fuel filter and drain some fuel to make sure there is no water in the tank. [Might be ice right now] Warm up the engine before changing the filter. :D
Note: I'm only guessing! But thats normal!:eek:
OK thanks Egon
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
