MF 135
/ MF 135 #1
Boit
Hiya, my problem should be a rather simple fix but I'm stuck at this point. Here's the deal. The tractor is a MF 135 3-cylinder diesel that belongs to my dad and his 3 brothers(they pooled to buy the machine). It is about 45 yrs old and runs fine. The problem is that the tractor sat unused for about 6-7 months thru the winter. My dad went to start it and it ran for about 10-15 seconds and died. It turns over fine but won't start. I suspected that it's not getting fuel so I managed to get a NAPA fuel filter for it and changed it out. The filter sits inside a clear glass bowl so it's easy to see when fuel fets to the filter. Can't get fuel to the filter. I even used the little manual lever pump to prime the filter...loosening the filter to purge the air but still no fuel. I suspect that the diesel has gelled during the cold and is blocking the fuel from getting out of the tank to the filter. I decided to take the fuel line apart downstream of the tank where it goes into the pump but the line won't come out of the pump. It's very loose as I can wiggle it around but I can't remove that end. I don't won't to beat on it and risk doing damage so I am at a loss as to why this line won't just pop right out. I tried a couple of other places in the fuel line that has the same connections and they all do the same thing. Is there a trick or method of getting these line-ends out? These lines are metal...looks like stainless as there is no rust. If the fuel pump needs replacing, I need to know how to remove the lines. Any help would be greatly appreciated.
Troy A.
Luling, La.
/ MF 135 #2
G'day troy the lines prob have got rubber sleeve on them just give them a good sharp tug once the nuts are undone. Check the tap up at the tank as there is a filter up inside the tank accessible by removing the tap . Good luck with it all :)
Jon
/ MF 135 #3
Having the same trouble removing the lines from the pump. I know it sounds simmple but these SOB's wont budge. Any tips or tricks?
/ MF 135 #4
My pump had rubber seals on the inside. Once I cut these the lines pulled out with easy. The new pump didn't have these seals and leaked like crazy. So I got sine small o rings and put 2 on the end if each line and tightened it down. Worked like a charm.
2019 BOBCAT MT55 WALK BEHIND SKID STEER (A59823)
2019 BOBCAT MT55...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
Unused 2025 CFG Industrial H12R Mini Excavator (A59228)
Unused 2025 CFG...
Yanmar YT359 (A53317)
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A60736)
2014 MAGNUM...
