MF 135 Z134 Engine distribtutor
   / MF 135 Z134 Engine distribtutor #1
Gpops
Troup, Texas
1965 MF135, Kubota B2301HSD
Does any one have any tips on re-installing the Delco distributor in a 135 with a Continental Z134 engine in terms of lining up with # 1 cylinder at TDC The manual doesn't provide a lot of info Thanks. Gpops
   / MF 135 Z134 Engine distribtutor #2
There is a peep hole on the left side if sitting on the tractor on the front side of the bell housing. The flywheel timing marks can be seen thru the hole. Pull #1 cylinder spark plug. Place a hard wad of paper in the plug hole. Roll the engine over till it blows the wad out of the plug hole. Now rotate and check the peep hole till you see TDC. Top Dead Center. The distributor should be pointing to #1 plug. You are now static timed. It timing requires before or after if can be tweaked while running with a timing light pointed at the peep hole. There is also a spring under the points punting plate which attaches to to centrifugal advance. If your going this far, you need to check those weights to make sure they move freely and the spring is still attached. Summit sells replacement springs in three strengths. The springs allow the timing advance while the engine is under load. If the advance doesn't work properly you will be sacrificing horsepower. Your owners manual has the timing settings.
thks a ton.. M new toy is a 65 135 that i named Bojangles.... lue the pic with u and your pardner take care and thanks again
   / MF 135 Z134 Engine distribtutor #4
BTW, unless someone changed engines, you have a Z145. I also have a 65 135 with the Continental engine. I've made a few changes to mine since I bought it. See my signature line for the link. Have fun and get those hands dirty. -kid
   / MF 135 Z134 Engine distribtutor #5
He could have "less" than a 145 if he has the "special", ie. does not have a tach or 2 stage clutch...I think they had the slightly smaller engine than the Z145.. I may be wrong, but I'm never in doubt...BobG
   / MF 135 Z134 Engine distribtutor #6
That's true Bob. Forgot about the "specials". -kid
The tractor has no tach and has a single stage clutch. The head and block castings show Z134 but I'm not sure that means a whole lot. Again thanks for the help Gpops
2017 CHEVROLET 2500 HD (A50854)
2017 CHEVROLET...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
2004 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
Stihl KM 130R String Trimmer and Edger (A49461)
Stihl KM 130R...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
