MF 135 won't stay running under a load
   / MF 135 won't stay running under a load #1
SteveG1
Emmitsburg, MD
1970 Massey Ferguson 135
Hello, I'm new member to the forum but visited numerous times as there is plenty of good information here. I keep coming back for information so I thought it was time to join.
I have a 1970 Massey Ferguson 135 with a gas engine and Zenith carbeurator. I bought it about six years ago and other than replacing some hyrdraulic hoses and an auxillary hydraulic pump I haven't had any problems; well, until now. We had a bit of snow last week and I was out plowing when the tractor tried to die. I found I could keep it running by pulling out the choke; but with reduced power. After a while, even that didn't work well. It would idle fine and would start to die as soon as I put it under a load. I also found that if I put the choke in fast, it will try to die. If I put it in slowly, it will idle just fine.
I thought there might be some water in the gas, so on the adivce of a mechanic I put Dry Gas in the fuel tank, which did not help. I also tried putting some carbeurator cleaner in the fuel and also sprayed some clener in the air intake. I also drained the carbeurator bowl. Nothing seems to be working. Any ideas on what I should try next? I'm not a mechanic, but am trying to learn to be on my own equipment. Thanks.
   / MF 135 won't stay running under a load #2
Disconnect the gas line at the tank to see flow. I think its clogged inside.
Murph,
You were correct. Not enough gas was getting to the carbeurator. There was quite a bit of junk that came out of the shutoff valve area. Things are working well now. Thanks for the tip.
Steve
   / MF 135 won't stay running under a load #4
Good to go! Good job!
   / MF 135 won't stay running under a load #5
Am cumparat recent un MF 165 mai vechi dar functioneaza bine si vreau sa-i fac schimbul de ulei in transmisie ( transmisia si hidraulica la un loc), cutia este in 3 trepte plus retur si vreau sa-i schimb si filtrul de ulei dar nu stiu unde sa desfac ca sa-l scot, Ma poate ajuta cineva?
   / MF 135 won't stay running under a load #6
TRANSLATED: I recently bought a 165 mf older but works well and I want to make him change the oil in transmission (transmission and hydraulics together), plus the box is in 3 steps back and I want to change her oil and filter but not know where to undo to get it out can someone help me?
Toro Workman Utility Cart (A51694)
Toro Workman...
SELLICK S80 STRAIGHT MAST FORKLIFT (A51242)
SELLICK S80...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2024 Polaris Ranger 1500 (A50514)
2024 Polaris...
Case 721B (A47384)
Case 721B (A47384)
HYD MULCHER HEAD (A51243)
HYD MULCHER HEAD...
