RKeithByrd
My MF 135 gas tractor will run about 30 min or so then dies but after an hour or so it will start and run fine for about another 30 min. Any ideas appreciated. Thanks. Robert
It is a 1969 4 cyl gas and when it stops it is like the key was turned off. I will try the things you listed above and let you know what happens. Thanks.
on the diesel there is a small filter in the top on the fuel tap in the fuel tank , maybe the same on gas tank?
this filter does clog up.
Ok so it could be that as the coil gets warm the resistance inside increases until there is no more spark. Most likely though is that the points are barely opening and as the engine warms up they don't open at all or develop enough resistance that they don't let any current through.
