MF 135 PTO shaft seal, how to remove and replace
   / MF 135 PTO shaft seal, how to remove and replace #1
texas791
Austin, Texas
MF 135
Hi everyone,
I'm stuck! Well actually the pto shaft seal housing on my MF 135 is stuck! I can't get the housing out. The retaining ring bolts and ring have been removed, but the housing does not "slide off the shaft" like the manual says it will. Any suggestions on what to try?
Thanks.
   / MF 135 PTO shaft seal, how to remove and replace #2
If I remember right the whole shaft assembly has to come out, then remove the snap ring in front of the housing. Use a punch in the PTO shaft hole and pry on the punch to get the assembly out after draining the rear oil. There is a large O ring that seals the retainer OD also.
Thanks, DieselTech. I'm going to give that a try as soon as the rain stops here in Texas. I'll use a bolt through the hole in the PTO shaft and a pry bar to lever the shaft out (sliding the housing off as it comes out). I'll probably need to replace the "O" ring on the housing so I have to order it.
Thanks again for the solution.
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
LMC G300JD LOT IDENTIFIER 231 (A53084)
LMC G300JD LOT...
