MF 135 PTO shaft seal, how to remove and replace
   / MF 135 PTO shaft seal, how to remove and replace #1
texas791
Austin, Texas
MF 135
Hi everyone,
I'm stuck! Well actually the pto shaft seal housing on my MF 135 is stuck! I can't get the housing out. The retaining ring bolts and ring have been removed, but the housing does not "slide off the shaft" like the manual says it will. Any suggestions on what to try?
Thanks.
   / MF 135 PTO shaft seal, how to remove and replace #2
If I remember right the whole shaft assembly has to come out, then remove the snap ring in front of the housing. Use a punch in the PTO shaft hole and pry on the punch to get the assembly out after draining the rear oil. There is a large O ring that seals the retainer OD also.
Thanks, DieselTech. I'm going to give that a try as soon as the rain stops here in Texas. I'll use a bolt through the hole in the PTO shaft and a pry bar to lever the shaft out (sliding the housing off as it comes out). I'll probably need to replace the "O" ring on the housing so I have to order it.
Thanks again for the solution.
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
Year: 2012 Make: Chevrolet Model: Traverse Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 177,... (A51694)
Year: 2012 Make...
JOHN DEERE F725 LOT IDENTIFIER 92 (A53084)
JOHN DEERE F725...
2005 TerraGator 8104 (A53472)
2005 TerraGator...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
Informational Lot - Shipping (A53472)
Informational Lot...
